Are you able to help with the another issue I’ve had with the shade benefit component? When inputting multiple shading or window breps I receive the following error - “1. This component can only accept one window brep per branch. Separate windows into different branches if you have multiple windows.”
Can you advise how I can overcome this to assess multiple custom shade devices with multiple windows?
@devang: I’ve followed the methodology in your GH screenshot example, but now receiving a different error: “1. Solution exception:Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index”
Latest GH attached with shading internalised. Please let me know your thoughts?
I took a look. I would recommend updating the who file using Ladybug_update File component. As you can see from the image it works without errors at my end. GH Energy Analysis_CURRENTDESIGN _SB_int.gh (964.8 KB)
