Dear sir or madam,
As the figure shown, I made two times simulation with same small blocks. First time is the two blocks, the last time is one blocks. But the result of the simulation is same. I suppose if I connect the two blocks to ladybug tools, the simulation results should be the sum of the two room. But it is not, it is the result of first room in the room list. I have tried several times, the result is same.
I am not sure if it is the bugs and I should reinstall the ladybug. Or I made mistakes in the grasshopper.
What can I do?
Thank you very much.
Regards
I have found the result is the energy consumption per m2, not the total energy. It is my mistake. Thank you. I have settled the problem.
