Honeybee Sky View results interpretation
I have run Honeybee Sky View component for Vertical Sky Component analysis. I have used the Hb Sensor grid from Apertures to assign the grid on the windows since the analysis is to be done only on the windows.
Now after the analysis, I am not able to handle the data in a way that shows the values of each window. I need to calculate VSC on each window.
Anyone who can give me a bit of direction will be of great help.
Thanks!
