I’ve been able to add windows to the walls, but for the skylights I am not able to create more than one- regardless of whether or not I put True/ False for the breakUpSkylight_ input.
I’m a new user for Grasshopper and Honeybee, and I’m not sure what I am doing wrong. Please help me, (also on a time crunch).
Thank you!!
please upload the gh file, without it, it is hard to say what is wrong. However you can see already that Honeybee_Honeybee is orange and you should check that
It’s not allowing me to upload the Grasshopper file as I am a new user, is there any way I can go around this? Also, thank you for replying!
You can send a link.
Wasn’t too sure how to do so, so I’ve posted a Google Drive link (open to the public) hoping this works. Thanks again for all of the help
https://drive.google.com/file/d/1pz47e3jBe58hC7RAHb7uDfJgSN2ZkLde/view?usp=sharing
Hey, thanks for replying! For some reason whenever I try to change the value of skyLightBreakUpDist_ it stays as the large skylight window, and doesn’t breakup. I’ve installed all of the software that I was missing (DAYSIM etc) so my Honeybee_Honeybee is no longer orange- so that shouldn’t be an issue anymore. However, I’m still unable to divide my skylight.
Thank you
Probably your units in Rhino are set to mm. Change that to meters.
It worked! Thank you so much
(Can’t express how thankful I am!!)
