Honeybee Solution Exception
Hey there!
I just installed Honeybee, Ladybug and everything on a brandnew machine. But somehow when I drop the Honeybee_Honeybee onto the canvas it tells me:
  1. Solution exception:name ‘EPVersion’ is not defined
Has anyone had the same problem before?
Have you installed the adequate EnergyPlus version (8.1 last I checked) on your machine? To the default location?
Yes I have… Did everything just like on my old machine, on which it runs fine.
Hi Albert!
Can you connect a panel to the output and send a screenshot of the error. The line number will help to understand where the problem is coming from.
Mostapha
Hi Mostapha,
I’m having exactly the same problem - just started happening on one computer in our office today.
Did you get to the bottom of it? Have exactly the same set-up on a different machine and it’s fine.
Ed
Hi Ed,
Can you please do what I suggested and let me know what is the line number? I can’t replicate this issue.
Mostapha
Sorry, thought I’d attached it, see below.
I’ve actually sorted the issue. Seems a newer version of EP had been installed on the PC alongside the previous version. Uninstalling the later version fixed the issue.
Thanks Ed. It was really helpful. I just got it fixed (https://github.com/mostaphaRoudsari/Honeybee/commit/808e592c06abdb7…)
