I have a little problem running THERM analyses into GH environment. It tells me “1. Your simulation did not run correctly because of the following error: The geometry contains voids or overlapping regions……” The problem born with files I created from scratch and from the example file found in HYDRA as well, so I don’t think is a problem related to my geometries and boundaries modelling.
How could I fix the problem?
The second question I have is related to RADIANCE. I installed many times and to put the program in the suggested file path, C:\ as you suggested in forums, but the component “Honeybee_Honeybee” still tells me that “Honeybee cannot find RADIANCE folder in my system”. Is there a suggestion for that?
Thank you so much in advance for your availability.
Luca Bortolozzo
