A couple of quick comments without looking at your file, to unblock you:
step of simulation_ only accepts Integers (numbers), that represents the step of your simulation. As an example, if you are simulating for a week and plug 12 into step of simulation, it will show the results at noon of the first day.
If you want to see a time average, you´d need to plug an analysis period.
I tried to take a quick look at your file, but there are some curves missing, so I can’t run it, can you update your file and internalise them?
Probably it’d help to check what is the operative temperature in your zones at that time, to understand whether it’s a simulation problem or the microclimate workflow itself.
Hello @WoodyHe. First of all please update to the latest honeybee ladybug components (november update). Secondly, try attaching two different component of analysis period to each. Adjust hour from 1 to 24. This worked for me.
Hi @WoodyHe ,I have found the error i guess. There is a zone which is not closed. I have encircled it. I ran the whole file without that zone with some changes, i got the values. I am reattaching the revised definition.
Its because of the zone i have disconnected and i have used my own epw file rather than yours. Dont get confused with that.
Please click on solved to help others.
I also just wanted to say that the reason why the mesh is still black is because it is clearly pretty cold in your simulation given the inputs to your PMV model. Try upping the met or close. Or just raise the setpoint in your energy model
