I don’t think you can change that, that’s is part of the metric.
You can read about it here
simply use the component which is called Read annual results 2, and set up your minimum and maximum threshold and your UDI min-max will be the “inTheRange” values
Thank you very much. Is the same tool used to modify the minimum DA value? Thank you again for your help, which is very helpful for my paper
OK, thank you. I’ll take the time to understand
