Hi!
The following reads when hovering over the heating input setEPZoneSchedule
A text string representing the heating setpoint shceudle that you want to use. This can be either a shcedule from the “Honeybee_Call from EP Schedule Library” component, a schedule from the “Honeybee_Annual Schedule” component, or a CSV schedule from the “Honeybee_Create CSV Schedule” component. If this is a custon schedule, the values in it should be Watts and the “units_” or “schedTypeLimits” input should be “Temperature.”
When I created schedules last time I remember that I input a list of temperature values right? Not watts.
lightingScheduless_: A text string representing the lighting shceudle that you want to use. This can be either a shcedule from the “Honeybee_Call from EP Schedule Library” component, a schedule from the “Honeybee_Annual Schedule” component, or a CSV schedule from the “Honeybee_Create CSV Schedule” component.
I suspect that the extra “s” in lightingschedules is the reason I dont get any floating text here at all.
Thanks for all the good work!
