How can i calculate radiation on a special part of a surface?!
Hi all
Could u plz tell me
how can i calculate radiation on a special part of a surface? !
there is a rectangle but I gonna calculate radiation just on the circular surface, radius of circle is 20 cm!!!
Capture5896
simply supply only the circle to the geometry input on the radiation component.
Hi all
I have a domed shape that I attached it.
I can calculate radiation on my shape.
How can I calculate radiation on a special part of my shape?
Capture2
thanks in advance
Draw a geometry there in the opening and connect it to the component as geometry. If you have other geometries which cast shadow on this geometry you can connect them as context.
hello dear @mostapha
I attache 2 pictures. it was simulated radiation on the 2 picture. Just one of picture has context.
However i dont know why total radiation on the both pictures are equal?
![Capture444|512x442]
(upload://xEURxfbkLvofykZRVCQig9qobjY.jpeg)
Capture44
Capture444
Why do you think they should be different?
How do you think this “context” is affecting the checked surface?
