How can I modify the function "createGlazingForRect"
Hello everyone
For a project, I need to modify the window’s dimension on Grasshopper/Honeybee whit out setting breakUpwindow to True, but apparently, you cant do that. Another option to change the window’s dimension is modify the base dimension in createGlazingForRect but I can’t find this script in Grasshopper/honeybee.
Can someone guide me in this problem?
Thanks in advance
Solved here Glazing Creator, break up window = False
