How can I run my energy analysis in honeybee passively?
hi guys,
currently I’m working on my master thesis and one part of it is about thermal resilience during intensive heat waves, and i need to run my analysis in a passive mode, i mean without considering HVAC systems. I’m wondering if i connect my construction to model to osm directly is it going to consider my analysis passive? i need to I want to know how long the building can be in the comfort zone.
thank you for your response in advance
Hello Shahintvk,
I assume you’re trying to determine the ideal loads of your energy model, excluding the effects of HVAC efficiencies. If that’s the case, it’s definitely doable; you can find tutorials online.
I hope this helps.
Welcome to the forum.
Set the room input “conditioned” to False.
