Firstly, I found that the LB Cumulative Sky Matrix does not support float number inputs for hoys.
Then I tried to use the Annual Irradiance component. I was confused by the fact that the results were also converted to annual data even though I set the hoys.
What should I modify please? Any assistance would be greatly appreciated !
