Hi everyone,
I prepared a quick example for my question as you can see the below image and .gh file,
I am trying to find separate results for different buildings in the only one analysis. After the analysis, how can i add thermal loads of zones only in same building? When i use the explode tree component, it gives me 70 match output (30 from 1st building + 40 from 2nd building). How can i understand that which one belong to 1st building or 2nd building?
In brief, i want to see;
1st building Total Thermal Load : x kWh
2nd building Total Thermal Load : y kWh
-Oğuzhan
separate results for different building.gh (654.6 KB)
@oguzhankoral,
You can separate the results based on the zones in different ways. e.g. using these components:
Or you can do like this way:
please find attached:
separate results for different building OMD.gh (704.0 KB)
@OmidmRashidi,
Its totally solved my problem. I couldnt be sure sorting of match output, your clear explanation provides me to understand.
Thank you so much
Hi @OmidmRashidi,
I have an extra question because there is wrong sorting in lists i think, most probably its due to the EnergyPlus, how can we fix it?
@oguzhankoral,
Zones’ names didn’t match with the results. The zones names were sorted based on each floor. And the results based on every 5 zones in the individual branch.
separate results for different building Omr_fixed.gh (716.8 KB)
kind regards.
You solved double
thank you again @OmidmRashidi
-Oğuzhan
