How come my grids/ mesh are multiplied?
When I only select one surface for analysis grid everything is fine, but when i select 2 surfaces it multiplies by 2, so there seems to be 4 grids insted of 2. Any logical explenation to this?
Two surfaces:
Hi @Falk,
Looks like the issue is due to your data trees input into SensorGrid.
First guess is that you need to graft your base_geo_ input, failing that interrogate your other inputs to check they all align.
Cheers,
Charlie
Hi @charlie.brooker
I do not think thats the problem, I have tried eveyr possible combination of grafting and flattening I can think of.
I either end up with 4 grids, 2 of each or just one.
Hi @Falk,
Grafting base_geo_ seems to work for me, is this what you’re looking for?
Cheers,
Charlie
@charlie.brooker
Yes works for me to, thank you very much. :slight_smile:
