I’m facing pretty much the same problem with the LBT 1.1.0. I made sure I did every step right and double-checked, the last time I even reinstalled everything that has to do with LB (also the Radiance, OpenStudio and so on). On this PC I have only LBT 1.1.0 installed, and in another one also previous versions of LB and HB. The older versions work just fine on the other PC, and LBT 1.1.0 shows the same error in both PCs.
‘1.Solution exception:“XX” was not found in the program type library.’
