How do I add Sensor Grids to a Model?
Hi everyone,
I tried all the above solutions one by one (also from another related discussion) but it’s still not running, and says ‘1. Solution exception: Model contains no sensor girds. This is required for this recipe.’
With the Assign Sensor Grids and Views component.
It sounds like you should probably watch some of these tutorials:
