When I am using ladybug tool to do Radiation Analysis, it sometimes showed the radiation of inside surface. So I need to manually flip them to show the outside. But when I compare the direction of surfaces which show inside radiation and outside, the xyz arrows are all same, which means I can not recognize them if I didn’t find them wired. I am wondering is there anyway to show which surface need to be flipped? Thank you!!!
The Dir command in Rhino may be helpful, it has an arrow showing the direction of the surface of analysis
That helps! Thank you so much!
