The skylight for the model has been made
How do I turn them into HB surfaces?After I connect, the computer shows that it is not a closed object. Why? i dont understand…
please look these pictures
The green part of the model is the skylight I want to add
Would you please tell me how to do I would be very grateful!!
The skylight is intended for horizontal windows. From your images i see they really are vertical. If so, you should use the add windows component instead.
