How do I use the HB Read Face Result component
Hello All,
Can you please help me with the following component? How do I get the output of the face’s indoor temperature and outdoor temperature? Where exactly am I supposed to connect it?
HB Read Face Result
Hi @Archie,
Is this helping you?
Hi @Erikbeeren
Wow, you’re awesome! Thank you so much. That seemed to have worked!
Hi @Erikbeeren
Adding on to the previous comment. What I am trying to do is to actually test the face’s inside and outside temperature when I change the thickness of the concrete wall. But when I change the thickness, there seems to be almost no change in the face’s inside and outside face temperature. You think I am doing something wrong or using the wrong component to achieve this?
Attaching the script here for your reference, incase you wish to see it. Thank you.
22 11 01 Honeybee new each face.gh (172.5 KB)
22 11 01 Pocket Lodge on Honeybee each face.3dm (83.9 KB)
Hi @Archie,
Concrete is not a good insulation material. So changes in thickness will not have a big effect. The biggest effect will be the accumulation of heat.
