How does the example of AFN in LBT1.3 work?
similar topic
maybe Earth Tube Labyrinth - Unmet Hours
https://energyplus.net/assets/nrel_custom/pdfs/pdfs_v9.5.0/EMSApplicationGuide.pdf
page 37 5.1.4 Outdoor Air System Node Conditions
to make use of a separate model, outside of EnergyPlus,
for some unique type of component (such as a labyrinth or earth-tube) that preconditions outdoor
air; the results of that model could be fed into the air system model in EnergyPlus using these
actuators.
The first one simulates the earth-tube only and then outputs the hourly dry bulb and wet bulb temperatures to a .csv file The second simulation utilizes EMS routines to replace the dry bulb and wet bulb hourly temperatures in the weather file with those found in the .csv output file but only for the outdoor air intake node… See code below: (note this was done with v.5)
EnergyManagementSystem:Sensor, Earth_Tube_DB_Sched, !Name EarthTubeDBSch, ! Output:Variable Index Key Name Schedule Value; ! Output:Variable or Output:Meter Name
EnergyManagementSystem:Sensor, Earth_Tube_WB_Sched, !Name EarthTubeWBSch, ! Output:Variable Index Key Name Schedule Value; ! Output:Variable or Output:Meter Name
EnergyManagementSystem:Actuator, ET_OADB_Override, ! Name DOAS Outside Air Inlet, ! Component Name Outdoor Air System Node, ! Component Type Drybulb Temperature; ! Control Variable
EnergyManagementSystem:Actuator, ET_OAWB_Override, ! Name DOAS Outside Air Inlet, ! Component Name Outdoor Air System Node, ! Component Type Wetbulb Temperature; ! Control Variable
EnergyManagementSystem:Program, SchedOA, ! Name SET ET_OADB_Override = Earth_Tube_DB_Sched, SET ET_OAWB_Override = Earth_Tube_WB_Sched;
EnergyManagementSystem:ProgramCallingManager, Schedule OA, ! Name AfterPredictorBeforeHVACManagers, ! EnergyPlus Model Calling Point SchedOA; ! Program Name 1
Output:EnergyManagementSystem, Verbose, Verbose, Verbose;
Schedule:File, EarthTubeDBSch, !- Name Any Number, !- ScheduleType W:\M\CALC\ETDB.csv, !- Name of File 1, !- Column Number 0, !- Rows to Skip at Top 8760, !- Number of Hours of Data Comma; !- Column Separator
Schedule:File, EarthTubeWBSch, !- Name Any Number, !- ScheduleType W:\M\CALC\ETWB.csv, !- Name of File 1, !- Column Number 0, !- Rows to Skip at Top 8760, !- Number of Hours of Data Comma; !- Column Separator
