How is the electrical equipment calculated in HB building program component? I tried deconstructing program to see values. So it shows 6.7 w/square meters. Is this value constant for entire day ? is time component considered in this value (like for how many hours this wattage is being calculated)?
For example if i have a residential building, I will use equipment for few hours only. let say i am using 20 watt bulb for 4 hours. then how to input this value in script?
How do we input the usage hours for these electric equipments?
