Reading old topics on this forum, I learned that infiltration was calculated as m3/s/m2 of floor area in older versions of HB (if I understood correctly).
As I started using HB last year, the only component I’ve been using is the HB Infiltration
, that takes a value of m3/s/m2 of exterior surface area.
I would like to know what is considered an exterior surface area by HB?
I’m guessing outside walls and roofs, but does it also include floors that are above a crawl space (exterior floors) for example?
Understanding this will help me to correctly translate conventional values that I have in m3/h/m2 of floor area to HB.
Thank you,
