How Ladybug_Radiation Analysis calculate the Radiation
I would like to know how the Ladybug_Radiation Analysis plugin calculate the radiation result for building surface. I go through the coding behind and found that it uses a function called “lb_runStudy_GH.parallel_radCalculator” to calculate the radiation result by inputs (Geometry, weather, orientation). Does anyone know how the function working and the math equation behind? Many thanks :grinning:
