How to add a glass radiance modifier to a HB aperture created by ratio
How do I add a HB Glass radiance modifier to a HB Aperture that is created by ratio on the solid face? Please see the screenshot attached.
Hi @deepthi.ravi there is a component called HB Apply Window Modifier in 1::Modifiers which will allow you to add the modifier after the apertures by ratio component.
I hope that helps
-Trevor
Thank you so much. That helped.
I have a follow-up question on this.
In the case where a glass/window construction or window modifier is not applied, what does the model assume as the U-value, Transmissivity, G value, etc? Where can I find that information on its inbuilt assumptions on the glass made by the ‘apertures by ratio’?
@deepthi.ravi here is a scene breaking down the default window construction set
the E+ object text from the window:
WindowMaterial:Glazing,
 Generic Low-e Glass,      !- name
 SpectralAverage,          !- optical data type
 ,                         !- spectral data set name
 0.006,                    !- thickness {m}
 0.45,                     !- solar transmittance
 0.36,                     !- solar reflectance front
 0.36,                     !- solar reflectance back
 0.71,                     !- visible transmittance
 0.21,                     !- visible reflectance front
 0.21,                     !- visible reflectance back
 0.0,                      !- infrared_transmittance
 0.84,                     !- emissivity front
 0.047,                    !- emissivity back
 1.0,                      !- conductivity {W/m-K}
 1.0,                      !- dirt correction factor
 No;                       !- solar diffusing
WindowMaterial:Gas,
 Generic Window Air Gap,   !- name
 Air,                      !- gas type
 0.0127;                   !- thickness {m}
 Generic Clear Glass,      !- name
 0.77,                     !- solar transmittance
 0.07,                     !- solar reflectance front
 0.07,                     !- solar reflectance back
 0.88,                     !- visible transmittance
 0.08,                     !- visible reflectance front
 0.08,                     !- visible reflectance back
 0.84,                     !- emissivity back
Hopefully that is helpful
