Hi everyone, I’m new to Ladybug and honeybee, I’m currently doing a project for my design class where I want to analyze different translucent facade patterns affect the amount of sunlight received inside the building. The roof facade is similar to glass with 80% transparency, so I was trying to set it as a glass window. I want to later run point in time sunlight analysis and annual analysis, but I’m struggling to set up the geometries for this simple analysis. I know it’s probably quite easy but I can’t seem to find any tutorials on that. If anyone know how i should set up the translucent facade patterns please let me know, of if there are similar example files. I have done sunlight analysis before using lady but so I just need to know how to set up the geometry for this part.
Thank you.
