How to calculate drag coefficient and lift coefficient with butterfly
Hi! Right now I am working on a project regarding drag- and lift coefficient of a simple structure. Up to where I am right now, it has been a long way. I realize now, that you cannot do it all just in Grasshopper. So I have my model in GH, I let it run, and then I have to change some of the case folders. After that I use the BlueCFD Terminal zu start the solving process again, giving me an output. However, my results are far off the value they should be. What can I try to change?
