How to calculate PGSV
Is it possible to calculate PGSV, which is a glare evaluation index, using the results calculated by Ladybug Tool’s “HB Point-In-Time View-Based” component?
According to the document below, it seems that PGSV can be calculated by changing the Radiance settings, but I did not understand how to change the settings.
I would appreciate it if you could let me know if you know anything.
Thank you in advance.
Hi @kaoriO,
Yes, that should be possible. However, you cannot use HB Glare Postprocess to calculate PGSV. You would have to create the masking file and run evalglare in command-line. Jan Wienold has an example in his presentation from this year’s Radiance Workshop on slides 92 and 93.
@mikkel
Thank you for your prompt reply.
I thought it would be possible to calculate PGSV using the results calculated by HB Glare Postprocess, but it seems like that is not possible.
I will try to find the PGSV using the materials you shared as a reference.
I briefly checked the documentation, but it seems difficult to obtain PGSV on grasshopper.
