I’m conducting research using HoneyBee and I have a couple of questions:
Is it possible to change the material of the shade component? If so, could you explain how I can modify the material?
Is it possible to add windows to the shade component? If yes, I would appreciate guidance on how to implement this.
The goal of my research is to observe how the heating and cooling loads change due to the influence of surrounding buildings. Any advice or suggestions on how to set this up would be greatly appreciated.
