Seems correct. As long as you edit the generated file called [insert_filename]_blacked.rad (and overwrite the file with your changes).
Sorry, I see I didn’t make it perfectly clear that you should NOT run “runRadiance”. So the process goes:
- Write “runRadiance”.
- Edit [insert_filename]_blacked.rad.
- Run “commands.bat” manually by double-clicking the file.
3.1. Optionally, add “pause” at the end of “commands.bat”. This will let the cmd window stay open after executing the Radiance commands so you can see if Radiance reports any errors.
- Import the result files in Grasshopper manually instead of using the output of “runRadiance”.
