Hello, I have found the indoor temperature distribution gradient after finishing the indoor microclimate analysis.
Could you please tell me how to express the specific number on the corresponding color block?
Because I want to find the specific temperature range in a certain horizontal or vertical direction
I do not fully understand your question, but I believe You want to find specific temperature values.
One workaround is You can set the gradient yourself, and change the color for a specific range so it is more visible.
This is an example where I wanted to specifically find values between 1.5 to 3.0
