. I need to generate a CSV file for each window that shows, for each hour:
• Fully exposed to sunlight
• Partially exposed
• Fully shaded
I’ve already used Ladybug’s LB Direct Sun Hours and have the int_mtx output, but I’m not sure how to extract and categorize each window’s hourly status, then export it to CSV.
Any advice or example workflows would be greatly appreciated!
It is not going to give you the window values but the sky dome’s values [total, direct, diffuse radiations]. Which is what you highlighted in your image.
It’s just one window I am analysing. I checked the Ladybug web it says the int -mtx only can output integers. So How can I define which window is partially exposed?
