Hello everyone,
I am trying to obtain the surface temperature of a specific element in my model (for example the first south-facing window on the second floor).
Currently I can read zone level outputs and general surface outputs, but I cannot isolate the temperature of one individual aperture/shade/wall instance.
I want to track the temperature of a single window (or a single shading surface) over time.
The simulation outputs seem aggregated, and I do not understand how to reference a specific HB object inside the EnergyPlus results.
Questions
- How can I request the temperature of one specific surface/aperture?
- Do I need to assign a unique identifier or name to the HB face/aperture?
- Which exact output variable should be used (Surface Outside Face Temperature, Inside Face Temperature, Aperture temperature, etc.)?
I attached pictures showing the case.
Thank you!
