Hi everyone, I have a question
I want to do energyplus to analysis the house
the Vedio which I learn link is https://youtu.be/2yTxyDegm68?si=on49Vvcp00vHnHIT
The problem is I do not know why I can not run the energyplus?
have anyone could tell me that Which step i have to change?
- The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][number_of_vertices] - “0.010000” - Expected number greater than or equal to 3.000000 - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][number_of_vertices] - Failed to validate against child schema #0. - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][number_of_vertices] - “0.010000” - Failed to match against any enum values. - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][number_of_vertices] - Failed to validate against child schema #1. - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][number_of_vertices] - Failed to validate against any schemas allowed by anyOf constraint. - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][sun_exposure] - “WindExposed” - Failed to match against any enum values. - The simulation has not run correctly because of this severe error:
** Severe ** [BuildingSurface:Detailed][7a8fd659c1f94e45ba9b][vertices][3] - Missing required property ‘vertex_z_coordinate’. - The simulation has failed because of this fatal error:
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
