I’m following along with a tutorial for a facade script that’s adjustable based on sunlight/radiation data (link: https://www.youtube.com/watch?v=J0RjO46wKcs) except it uses a slightly older version of Ladybug than what I currently have. They’re using the old Radiation Analysis component whereas the closest equivalent I have is the Incident Radiation component; however, they’re using the Radiation Analysis component as they need the [radiationResult] output that’s provided by that component, which Incident Radiation does not provide. Does anyone know a work-around I could do, or otherwise how else to obtain that output?
I included an image I took from @Ertunc 's post (Difference Between "LB Incident Radiation" and "Ladybug Solar Radiation" Components) as it shows both components side by side.
