Hello All, I am trying to plot data generated outside of Grasshopper onto a Ladybug psych chart, but I cannot figure out how to do this. I’m still quite new to Grasshopper and Ladybug.
I have gone through Chris Mackey’s excellent youtube tutorials on the psych chart, I have scanned the forums and googled my best, but am still stuck so any assistance would be greatly appreciated!
My assumption was that I could copy DBT and RH data into panels and then plug those into the psych chart. This isn’t working but I’m not sure how else to approach this.
I have tried a few things and have come across the following errors:
The psych chart does not work if I plug in more than 2 data points for dry bulb & RH (unless I’m plugging in EPW data, of course). I get the following error: “1. Solution exception:index out of range: 0”
I can’t paste in all 8760 lines of data into a panel. Sometimes I get around 4700 lines in, other times, it’s around 5600. I thought it was an issue with not being able to store that much data while copying, but when I hit a return after the last line of data, it doesn’t let me add another line.
(perhaps related?) I noticed that if I plug EPW data into panels and then into the psych chart component I get the error: “1. Solution exception:unsupported operand type(s) for -: ‘str’ and ‘int’” I assume this is why just copying data into a panel to plug into the psych chart component doesn’t work?
I have attached examples replicating the above issues. Thanks in advance for your help!
psychChartProblems.gh (527 KB)
