I have created an example file on how to use LB+HB for polish sunlight hours code compliance. It works if you use the specific link, but it does not appear on the general hydrashare. Am I doing something wrong? Or it needs time to update?
http://hydrashare.github.io/hydra/viewer?owner=protactinium91&fork=hydra&id=Polish_Sunlight_Hours_Compliance&slide=0&scale=1&offset=0,0
It should be loaded now! There are a couple of issues with Hydra! I’ll try to fix as many as I can tonight.
Also thank you for sharing the compliance code sample.
Thank you for help! I am happy to contribute!
