Hi everybody,
I have another question for you!! Is there a way to plot the Zone Windows Total Transmitted Solar Radiation Rate in the model? (as you can do for the operative temperature through the Microclimate Map Analysis component).
Because i have been using till now the 3D Chart (image attached) but through that component the result is not directly related to the model.
Thanks a lot in advance
Claudia
