Hello!
I have a question.
Now I’m trying to use ‘LB Direct Sun Hours’ component and this component needs geometry for its simulation.
I made the room by using ‘HB Apertures By Ratio’ component, but ‘HB Apertures By Ratio’ component makes one hb_obj not geometry
Anyway, What I want to know is… How can I deconstruct this hb_obj… or How can I extract floor and context geometry from hb_obj?
I solved the problem like the image attached above, but I’m writing to see if there are any other methods or components.
Welcome to the discourse.
Try the HB_VizByType component.
Thank you for your answer!
It works!
