Hi everyone,
Im currently doing an energy simulation with a district heating and cooling system (Template : DOAS with fan coil district chilled water with district hot water). After I run the simulation, instead of getting the heating and cooling demands by room ( 20 of them), as if i were doing it with ideal loads, it all gets summed up together. Is there a way I can seperate the heating and cooling results by room to see which are consumming the most? Maybe a specific SimulationOutput is needed in the HBSimulationParameter component ?
Thanks for your help !
