Hi. I would like to ask how to set a constant threshold value for the mesh selector.
I tried to use “replace items” to make a list with same length with “input mesh” list but it doesn’t work.
The error message is “1. The number of faces in the _inputMesh does not equal the number of values in the _analysisResult. Are you sure that you connected a mesh that matches your input data?”
Thanks.
