I am trying to set the option for Unmet Hours Tolerance in a Honeybee energy model workflow. Is there a way to set this parameter or do I need to feed it in as a string?
The EnergyPlus parameter is:
OutputControl:ReportingTolerances,
1.0, !- Tolerance for Time Heating Setpoint Not Met {deltaC}
1.0; !- Tolerance for Time Cooling Setpoint Not Met {deltaC}
Thank you for the suggestion. Yes that works!
Wonder if there is a built-in Honeybee method for doing this…
No, this is one of those input’s that’s a bit more advanced and isn’t natively supported by Honeybee. Using add_str_ (aka. additional strings) is the correct way to add it to your models if you need it.
Is this still the case with the newest version?
