Hello
How to have an internal shading in Honeybee Tools? I want to use a Face to reflect light into the indoor environment.
Hi @Mohammad.hakim.a
If you are doing daylight modeling, just set interior shading as wall or mirror material.Radiance will automate calculate the reflect of the interior shading.
Check this file. The effect of daylight reflection is not seen.
Daylight.gh (76.2 KB)
Nobody can help me?
I suggest rereading the forum guidelines:
Ladybug Tools Forum Guidelines
From your post, it’s completely unclear what version of the plugin you are using or what type of analysis you are running. You can assign shades to the interior of an object using the “HB Add Shade” componet:
Hopefully, that answers your question.
