Hi all and @chris
I am currently modelling a small hut and simulating the indoor temperature using HoneyBee. It is just a usual step where you have to create a room and simulate it. It can be easily done.
However, if I want to add the effect of a nearby large concrete wall and also a concrete ground, what is the best component to do in HoneyBee?
I am not sure if HoneyBee is capable of doing this radiation and conduction. Since we have to put everything as a room in order to do the EnergyPlus simulation…
I can try building a “room” with the thickness of that concrete wall, but not sure if this will do the trick since it is not a room but a solid object
Update: haven’t solved this yet, nobody has ever tried this in honeybee?
