Is it possible to simulate hybrid ventalition(natural ventalition and air-conditioned) with honeybee? For example, if the outside temperature is between 19-23 °C then use natural ventalition, otherweise use air-conditioning if set point of room temperature hit the set point for cooling and heating? It is like the chapter about hzbrid ventalition in the paper http://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=1034&con…
Yi,
You can absolutely do this with Honeybee. See this discussion for more information on how to set it up and for recommendations on thermostat temperature set points:
http://www.grasshopper3d.com/group/ladybug/forum/topics/how-is-natu…
-Chris
thanks for the guide to link. I asked a further question there, if it is possible to use setback for heating and cooling in hybrid ventilation, do you have any idea?
