- Solution exception:‘ascii’ codec can’t encode character ‘\u7EFF’ in position 170: ordinal not in range(128)
Hi @chenyi is it possible that you use a special character somewhere in your script?
I used the correct characters,is it the problems ofthe system or the installation path?
then I suggest to read this one here, if not done already.
and provide a sample file accordingly if possible?
thank you!l found i used special character in weather file,and i slove this problem
i have a new problem here,can you help me see what’s wrong?
The result file does not exist.
