For problems regarding the update components, I wanted to disinstall and reinstall HB and LB. The file I downloaded at that link is only about Honeybee, and it doesn’t work anyway (error message: 1. Solution exception:WindowsError). Then, I decided to delete the files like @AbrahamYezioro said, but I don’t know exactly what: I have multiple folders.
Can you please help me how to delete ladybug since im new to this. I am trying to get an older version of ladybug since I dont find any tutorials for the new version.
I’m experiencing the same problem. I’ve tried various ways but can’t seem to uninstall LB v1.8.
I’m waiting for Mostapha to respond after trying various ways including using the uninstall LB script he shared early in the forum which says the uninstall was successful but it’s still there. I’m hoping I don’t need to uninstall rhino completely as this was the only way we could get the uninstall process to work for LB tools last time there was a update.
I’m also wondering if we should completely remove pollination to see if this is what prevent uninstalling v1.8?
there’s no problems with installing or uninstalling v1.9, it’s only 1.8 which is causing problems.
