Hi everyone,
What a brilliant tool for energy and daylight simulation . I have some problems for dynamic control for blind . I want to control the blind’s angle for every hour . I know the honeybee[+] can solve my trouble. Can you tell me if the battery to solve my issue ? And how can I use it for my simulation .
I have an idea if I can use 10 shade state to control the blind ,which is 0°,10°,20°,30°,40°,50°,60°,70°,80°,90° .
And I have a .csv file that contains the angle of 8760 hours a year, but how can I achieve the control angle?
If you have the csv file with desired blind combinations you can bypass this component. Load csv values into Grasshopper and connect the values directly to blindStates input of other post-processing components.
Hi mostapha
I have a csv file angle.csv (31.8 KB) just contains the 8760 angles which correspond to the time . Here is my problem that I have no idea to use this file to control .
