How to use the Adjacency "adiabatic" setting
Hello!
I am a newbie when it comes to this software.
So, please forgive me if I ask a rather rudimentary question.
I have a question about setting up adjacency insulation.
There are three main questions.
Think of all the diagrams as floor plans.
I believe that the current “Honeybee+” has an adjacency setting.
I understand that “adiabatic” in this setting means that it does not take into account the heat exchange between spaces, even if there are spaces next to each other. (fig1)
Specifically, I believe that this setting is recommended to be used when the adjacent spaces have the same air conditioning settings. (Since there is no difference in temperature between adjacent rooms…)
My first question is whether this is correct.
If it is correct, then the next question is.
Is it possible to simplify the model by using the insulation settings of RoomA and RoomB?
Reproducing all the rooms in a real building is a very burdensome task.
If I only need the calculation results for RoomA, if it is possible to set it up in this way, I can simplify the model considerably and reduce the burden, but what do you think? (fig2)
fig2
And now for the last question.
If it is possible to simplify it as in the second question, is there any way to simplify it in the same way when the adjacent room is a non-air-conditioned space?
In Japanese load calculations, the temperature difference between inside and outside is often set as a factor (typically 0.3). (fig3)
→Inside/outside temperature difference = coefficient * (design temperature - outside air temperature)
fig3
The results obtained with this method may be a little less accurate, but it can dramatically reduce the number of models (rooms).
In other words, the time and effort to create and set up the model is drastically reduced.
Is there a simplified way to set up Honeybee+ for this type of space where the adjacent rooms are not air-conditioned?
I don’t speak English, so I used the translation function.
I know this may be confusing, but please let me know!
Thanks for the great software.
The answers for questions 1 and 2 are yes and yes.
As for the third i’m afraid the answer is no, but as you said, it depends what are you willing to “sacrifice” for accuracy. If the difference in the results is around 5% i believe you can simplify the model, otherwise you should consider modelling such unconditioned rooms.
One interesting fact about the adiabatic boundary condition is that it works by mirroring the boundary conditions of your surface. So it’s not just simply modeling zero heat flux, the heat is actually transferred into the surface from a zone, and the same process is mirrored across the plane of symmetry from the other side of the surface. Since there’s no temperature difference in the mirroring, there’s no heat transfer, hence it’s adiabatic nature.
EnergyPlus does this so that the adiabatic constructions can still model the impact of thermal mass in your surface (which is a trick they also use with internal masses).
Thanks for getting back to me so quickly!
I understand about what you mean.
I’ve made great progress in understanding that if the air-conditioned spaces are adjacent to each other, the results can be obtained without modeling both.
It seems reasonable to do some modeling if the room next door is non-air conditioned…
The relationship between adjacent rooms is very important because the same is probably true not only in plan but also in section.
I’m sure this knowledge will go a long way in simplifying and making your computational models more accurate!
Thank you so much!
