How to use the battery block of solve adjacencies ?
If we establish a five story public building with separate HB Room for Solid for each floor, will it result in separate calculation areas for each of these five story rooms instead of conducting overall calculations?
In other words, does the energy consumption of each floor appear separately, rather than calculating the five floor rooms as a whole?
If it is calculated separately, what should I do to make these five story rooms a whole model for calculation?
Hi @YueWN ,
I’m at a little bit of a loss to understand what you are asking about here but it seems like going through this youtube tutorial series will likely answer your questions and show you the workflows for building multi-room energy models:
